Turning
Re: Knot Hole Repair
Re: Knot Hole Repair ()
Mequipment
When you are sanding the bowl collect some clean wood dust and mix it in a small paper cup with some wood glue and pack the void with the mixture, the color will be similar to the work piece. You can finish sanding it when the repair is dry. You should clean the knot whole surface area with a Dremel tool or Dental pick to clean the loose material from the void and roughen the surface for the glue to adhere to.
