Turning
Re: Bent Hollowing Tool
Re: Bent Hollowing Tool ()
Mequipment
If you are turning segmented pieces, you can turn the piece as you add rings and not have to try and hollow the piece starting from scratch working your way to the bottom. Each time you glue a segmented ring to the stack you can turn the inside profile and have easy access to turn and sand the inside as you go.
