Turning
Re: Heat problem?Response To:
Re: Heat problem? () Pete in Holland MI
Bill - - Generally......bearings by themselves run with little heat. In a situation where there are 2 bearings, and either because of design, or installation, the pre-load can be too much. Does your spindle turn freely without the belt in place? If not, I suspect excessive pre-load and should be investigated.
Pete
