Turning
Re: 2 Morse Taper Collets
Re: 2 Morse Taper Collets ()
Mequipment
Your Morse Taper mounted collets and drill bits will have a more precise mounting for your work piece with less run-out compared to the screw on options. Anytime you add an additional threaded attachment to your spindle you add additional run-out based on the precision of the attachment and how well it mates up to the spindle flat, foreign material on your spindle thread or flat can throw the tolerance off on a screw mounting.
If you turn your work piece in stages and remount the work piece you are better off using a Morse taper mount which is easier to get the work piece to align when remounting.
