Turning
Re: recess vs tenon *PIC*
Re: recess vs tenon ()
>>>The recess usually provides a solid mounting of the work piece that provides good support for sanding, polishing...
As described here in the past, I remove the piece from the lathe for final smoothing with hand scrapers and sanding with ROS or by hand. The recess holds it securely while I work on the top/inside. By this time the bottom is completely done, using the same methods.
