Turning
Re: hollowing redbud
Re: hollowing redbud ()
John lucas
Rpm should not matter. Slow enough to be safe, fast enough not to take forever to hollow. The flat carbide tools are just scrapers and you always use a scraper with the cutting edge horizontal or a little lower. When hollowing with a scraper you should be cutting at or above center. If you cut below center it can pull the cutter into the wood. Same is true if you cut with a scraper tilted up.
