Turning
Re: Vac pump questions
Re: Vac pump questions ()
John lucas
When you have a vacuum chuck within easy access you find that you use it a lot. I have mine set up with the hand wheel bored to accept the bearing from the hose going to the motor so it can be instantly set up. Just put the chuck on. Plug in the bearing, bring up the tailstock to hold it. Turn on the pump and start turning.
