Re: Likely solution!
Re: Likely solution! ()
mark paulley
Everyone thanks for the help, internet was down and i could not respond till now.
I was cutting out bread saws and then moved to cutting some square 2" blocks for bird houses when I started hearing this grinding noise. Stopped and notice blade on back of wheel, re-positioned and turned by hand and the blade continues to move to the back of the wheel. I will clean the rubbers on the wheels and start trying to figure this out. Good news is I had all of my bread saws cut and approx 20 bird house squares cut so I can at least build a little inventory before my show on Thursday.
I am not very mechanical minded but will take it slow and work through each suggestion till fixed
Again thanks to all of you machine gurus!!!!!!!!!!!
