Turning
Re: Besides changing blades what else?
John C Lucas
Just read through all of the replies. If you go through each one it should solve your problem. Pull the guides out of the way. Loosen the blade and move it back to center. then rotate by hand and adjust the top wheel tilt until it stays centered. If that doesnt work then go through the list and check all the other things.
