Turning
Re: Hunter question
Hunter question ()
Julian
I recently used a Hunter cutter on a hollow form. I purchased the cutter separately from AZ Carbide and used it on my homemade hollowing rig. I used a 10mm cutter and found it to cut fairly smooth on end grain but a little rougher on the side grain. It takes some practice to get the cutter angled correctly for a smooth cut. But I will definitely use the Hunter cutter again and even purchased a 12mm cutter which I think is the #5.
