Turning
Re: Two improvements to my tool grinder.... *PIC*
roger lance
Mr. Jamieson.....it's an honor to speak with you. The plywood base to which the grinder is attached was originally designed to accommodate not only the Wolverine jigs but also the Lee Valley Veritas base.....
As you can see, I can slide the grinder out toward the table front and; since I've gone to the wider CBN wheels (1 1/2"), the Veritas unit will not work unless I modify it. Therefore, the front few inches of that plywood base could be cut off....trimmed....and I could gain the space needed to get your grind.
You're up in God's Country.....I'm in Grand Rapids.....maybe, one day I'll take a class with you or attend a lecture.....something I'd like to do.
