Turning
Re: Chainsaw winter adjustments? Follow-up
Keith Newton
I thought I would share my findings. Everybody knew it was a fuel problem, and If I hadn't just filled it, I could have easily discovered the problem. When I finally emptied the tank, I could see that the fuel line had a twist about 1" back from the filter.
When I pulled the line out of the fill hole, I could also see a hole, and the line was flattened and sticky, so had to replace the fuel lines, since there are two parts.
Thanks to everyone for the help.
