Turning
Re: Crown Revolutionary Hollower
Mike Brazeau
I made the same recommendation on a similar thread the other day at the AAW Forum - have a look at what Lyle Jamieson has done in adapting a No. 1 Hunter tool. It is mounted on a 3/16" short bar and mounts in his swivel adapter. I have had one with for several years and use on my home built Jamieson design and it works superbly. See it at link below in Tools & Jigs. You do not have to worry about a shield controlling depth of cut, works on wet or dry wood. I also use in a hand held CRS bar for boxes, shallow hollowing or under cutting bowl rims etc. Would probably be adapted to you existing system easily.
