Turning
Re: Jet 1442 Question
Re: Jet 1442 Question ()
mikeee12345
The knocking sound can also be caused by the bad pulleys rattling against the belt.
Running the lathe while it is making that noise will usually shred the belt and cause
the pulleys to fail. You might want to order an extra set of pulleys and keep an extra
set on hand. The pulleys are the most common item to fail on these drive types. The
on/off switch is another common item that is worth while having a spare on hand.
