Turning
Re: Jet 1442 Question
Re: Jet 1442 Question ()
ben d.
There are 3 bearings in the head itself, 1 ea. on the outer end of the spindle shaft and 1 on the shifter fork that changes the speed and that is probably where the knock is coming from had the same thing on mine one time. If you order pulleys be sure to order the keys for the shaft and the motor shaft as they are not standard keys. Bearings can be purchased locally. Pulleys are sold in sets and will most likely will have to be slightly reamed or sanded out to fit. I was told this was for compensating for shaft wear and you can get a good fit of the pulley to the shaft.
ben d.
