Turning
Re: Routing Question
Routing Question ()
Paul Grenier
You should start out with the ogee bit at final height and use the fence to increase the depth of the cut. To do this, you would make a pass completely around the piece - the use of a backer block is always a good idea with boards of this width - with the fence set so that you take no more than 1/2 of the depth of the profile in one pass. Cherry is especially prone to burning, so I always make 1 last pass that is the equivalent of 1 or 2 layers of blue painters tape thick. I accomplish this by applying the layer or layers of blue tape to the fence and then removing them for my last pass.
