Turning
Re: Hunter Viceroy *LINK*
Re: Hunter Viceroy ()
You can buy them directly from Mike Hunter at the link I provided. I made another platter this morning and played with other orientations of the cutter. The way the metal under the cutter is designed it's very easy to use this as a depth of cut limiter. This allows you to control the cut better to get a more perfect arc when hollowing out the bowl or rounding over the large outer rim of a platter. You can tilt the cutter so it faces the wood and do a shear scrape to help fine tune areas. A sweet tool. Here is a link to his main page. He is also listed as an advertiser and supporter of this Forum
