Turning
Re: X 2
X 2 ()
John C Lucas
Although i agree with Lyle and the others sometimes its not a bad step inbetween. I had an old Jline lathe that was similar to the Delta. It was missi g a tailstock quill and had a bent spindle a d no tool rest. The price was right. A friend turned a new spindle with 1 1/4" ×8 threads. I found a Delta quill that was 1/16 too large. I turned it down to size on the scbool lathe and then made a tool rest. Now i had a much more substantial lathe than the Delta 46_700 pirce of junk. Did some searching and found a DC motor and john jordan controller. That was definitely a step up. Several years later i bkught a used 3 phase motor a d was able to get a VFD at a.reasonable price. Installed that a d then made riser blocks out of MDF for the headstock and tailstock and made a new tool rest. Now i had a 16" lathe with state of the art power. That was pretty good until.i found a deal.on a Nova 3000. Put the motor and VFD on that lathe and put the DC motor ba k on the Jline. Sold the Jline and purchased another bed extension for the Nova. Then the Powermatic 3520 came out. One days turning on one of those and i knew i had to have it so i started saving. Finally got the 3520A which i still use. Why am i telling you all.of this. Modifying a lathe can be done and if your ha dy with tools and electronics you can ha e.the satisfaction of saying you did it. However. It is such a pleasure to.turn on a modern well built machine that if there is any way in your budget to.buy a new one you will never regret it. All of the modifications i made were useful and did work but were all compromises..
