Turning
X 2
Re: Variable Speed?? ()
Keith Newton
There is no good reason to put lipstick on a pig, because it's still just a pig.
You might be able to find a cheap 3 phase motor that is the right power and size to mount easily, but not all of them are compatible with VFD.
Then I've never seen one of the lathes this size that was very stable, if you choose to try larger out of balance blanks.
You'll be much better off just moving on up to a better lathe.
