Turning
Re: renovating Powermatic 3520B
As long as you can get the proper motor mount that part should be easy. The controller mounts on the back so you may have to jury rig a mounting system if the screw holes don't match. Running the wires should be easy. The reason I bought my Powermatic over some other lathe was because you could do what your trying to do. When you consider the cost of a new lathe that's a lot of savings. As long as your are up to wiring everything up the go for it.
