Turning
Ditto on Vince discs
John lucas
The. Best thin b I ever did was to buy a disc for every grit. Yes it's expensive but your discsoever wear out. You aren't pulling the velcro disc off a as often so it lasts a long time. I have only had to replace one pad over the years. Some of mine are so old the rubber cushion is startin b to deteriorate and the velcro is still good. Vince newer discs have interface pads that are a lot less expensive than the whole pads so replacementioned would be less.
To repair the pads use E6000. I compared it to Goop one day while fixing some shoes andHandgunner45 I can't tell the difference in the two except E6000 is easier to find.
