Messages
Re: Dipping My Toe In The Vacuum Press Water
TomD
I should mention that if you want to try out some vac bagging with a vac cleaner, be sure to have some air passing through to cool the motor. We used to use 4, 1/4" holes. I don't know what you need to use if you have a 5hp vacuum cleaner, and I would not use a 500 dollar one either.
You can figure it out by attaching your vac gauge to the hose with all the holes blocked, then peel them back, or adjust your vent slider until you see the load drop off, if you have opened at least as much as the holes mentioned, and the load has only dropped moderately, you should be good.
