Messages
As a practical matter......
It is becoming clear that most use this machine for finish sanding and not adjusting thickness or smoothing teeth parks from veneer. And absent the marvelous tool, I can see where changing belts to go from coarse to fine on the task would not be considered desirable.
In the past few days I have needed to adjust the thickness of 5 dozen strips for bent lamination. In some cases they were sawed too heavy so that up to 1/16" needed to be removed. Anyone with this need would not find 150 grit belts or sticking each piece on with tape practical.
Now that I can change belts in a short time I will be doing initial sanding with something as coarse as practical. I have never sanded coarser than 80 so I was looking for what was optimum. It will be pricy buying a pack of several grit sizes to find out for myself. I'll post results in time. I was able to mow off 1/4 turn on a 4" wide strip of white oak with a 36 grit belt. But before I could explore this option I ruined the belt.
For the 1 1/2" wide strips of cherry I used 80 grit and it was slow. For the show faces I finish sanded with 120 following the 80.
