Messages
Re: OT: ID This Lattice Material?
Keith L Newton
Maybe HDPE or 3Form. But if you want to get that look a lot cheaper, I would go with MDF or HDF if you can find it. I think if I were going to make that, without a CNC router, I would start by jigsawing a template from 1/4" MDF, then using a bearing over router bit or template in the base to do the actual cutting. Then painting the final sheet black would give a pretty good likeness for that look.
