Messages
How to stretch your Bloxogen
When a liquid vaporizes the volume increases about 20 fold. Hence a can of liquid that vaporizes in use will make vastly more "gas" at atmospheric pressure than a can of pressurized gas such as Bloxogen.
Dust-Off is a liquid in the can. And it is very heavy and will sink to the surface of a can of varnish. Problem is it is readily soluble in finish and if it is used alone to displace the air in a can head space a vacuum will be created when the stuff dissolves in the finish. The can will collapse.
Solution: Displace all the air with a robust burst of cheap readily available Dust-Off. Then displace some of the Dust-Off vapor with a quick squirt of Bloxogen.
