Messages
Re: Making a flag case quick question...
All of the old adhesive must be removed before the
The bottom joints have a lot of glueing area so they are good. The top, back will be reinforced by the glued on back so it is OK. The only weak spot that I see is the top, front, miter. I would reinforce it with 1 or 2 small brads tapped under the surface and then filled.
It is a wonderful thing that you are doing.
