Messages
Anything that the extender sees
Re: Depends on hook up ()
Mike L
If you can wire it then there will be no slow down. If it is just using the same wifi signal and boosting it then, anything that is using it will be slowed down. Are you using this for HD video or streaming TV? If not then you may never notice it slowing down. If so you will see it slow down when other people are streaming TV or games.
To wire it all you need to do is run a Cat 6 E-net cable to it from the router. Normally with 4 ports on the back, just plug into one of them and the other one into the extender.
The current extender is it wired or wire less? Just run a test for a few days in your shop and you will know if it will work for you or not.
