Messages
Re: Planer keeps going out of adjustment
Keith Newton
If the hand wheel or crank stays where you locked it, then I'm with the PM guy. It may be a set screw in one of those parts is loose.
Why don't you try just putting a board in between the cutter and bed, then crank it up against it, and see if you can keep turning it. If you can look underneath while you do this, maybe you can tell where the turning quits.
