Messages
Trivial solution to problem
OT-tankless water heaters ()
Calculate out how little volume there is in even a 100' run of pipe. Or how little time it takes to fill 100' of hose. The problem is flow, not volume. The problem is readily solved by doing away with the flow limiters the water deficient folks in CA mandated upon the rest of us. With the flow 60 psi is capable of delivering it will not take long to get hot water anywhere if you remove the limitations. .
