Messages
Finish expecting...
david weaver
...that you may find something when finishing that you won't see without finishing.
I don't sand much, but when I do sand, I look at what I've sanded twice. Once with raking light in the shop, and if lucky, with daylight at some point, but if not, a second look with raking light. Sometimes the second look (spread apart by more than seconds) finds things - just something about how our brains work.
But you will still sometimes find things (because I sand rarely, it's more often scraper ripples or something of the like) you didn't expect to once you add the reflectivity of finish.
I almost always seal with shellac - padded or brushed, so spot removal, correction, and then pad shellac back on where spot removing - no problem.
Shellac is a pain to sand off, spot removal is always with a scraper if something was sanded, and then resand the spot so as not to load up a bunch of sandpaper and burnish or mark up a surface.
