Messages
Re: Sanding to perfection question? Need Help
Don Stephan
You didn't mention the sanding schedule. Not sure what should be the starting grit after the grinder but if I use 80 grit I follow with 120, 180, 220/240, 320. After 320 if i wipe the surface in small circles the fine sanding dust packs into coarse scratches, highlighting them. I think 400 does an even better job of packing into scratches and highlighting them.
