Messages
Re: Painted Kitchen Cabinet Doors
Dick Coers
No idea about the Fuji. But if you haven't painted, a couple of suggestions. Spray a coat on the plywood panel before assembly. No line will show up next winter when frame shrinks. The face joints on the door frame is always susceptible to paint cracking, I don't have a perfect solution. Break the edges of door heavier than usual. Paint won't build on a sharp edge, it has a tendency to flow away from it. Primer chose is critical, as well as preparation. Nothing shows poor sanding technique like painted panels with lots of windows and light coming in. Don't assume the plywood is sanded well. Sand it like the hardwood! Hope you have a good SW dealer for support.
