Messages
Re: OT- Electric meter base replacement?
Dick Coers
"Seems like a pretty straight forward project as both cables come into the bottom of the the box." Both? You are talking about the main meter right? You should be talking about 3 cables right? When I had a new service put in the house, the only real trick the electrician mentioned was a heavy taping of the neutral so the inspector would trust that you had marked and carried the common wire up to the weather head.
