Messages
Re: Corner Cupboard Rev 2 *PIC*
Alan Young
This is getting Close---I like the molding design that separates the upper case from the lower case. My eye would like to see some more "weight" to the base...ie the Molding above the lower cases arch-BTW That Arch is very pleasing to my eye. "Weighting" the bottom molding may be just as simple as "switching" the moldings.
On the other hand it depends on the "viewing space" where this cabinet will be. If there will be open space between the viewer and the cabinet then my eye would like to see this weight added/switched toward the bottom. On the other hand if other pieces of furniture-ie dining tables and chairs etc will be within 4 feet of this piece then the large visual would be less likely to be a factor.
