Messages
Re: At a guess...
At a guess... ()
Ralph Lipeles
You can eliminate the explosive concerns by doing what I did when I made a dust/chip collector system using plastic pipe. I drilled 1/8" holes about every foot and a half. Next, I put a screw into each hole extending slightly into the inside of the pipe but not bottomed out. Then, I wrapped a strand of copper wire around each screw and finally attached the end of the wire to a known good ground.
