Messages
Re: Will this clothes rack design work?
1. Don't drill pole hole through the side so as to have a clean side appearance.
2. Select lumber for sides to have an attractive grain pattern, ideally 3 or 4 boards with "vees" nearly centered.
3. If finishing natural use a water based acrylic. It won't yellow. Oil based finished will yield an ever darkening yellow that I don't find attractive.
3. Your proposed construction is sufficiently robust and atrtactive. You won't have a happy time dovetailing ash. It is hard and I don't fined ring porous woods to be easy to scribe. But it will come out ok.
4. You could set a back into a rebate below the bottom shelf. Make this shelf high enough to accommodate shoes beneath. Arc it slightly so its center is off a possibly humpy floor.
5. Pegs below the rod will be a useful addition. It is more handy to hang some things in use off a peg than a hanger.
6. Post a PIC of finished product.
