Messages
Re: What is going on here? Gap between boards.
Brian Holcombe
Unless you're planning to glue these all at once, I would clamp up 4&5 and see if clamping them closes the gap. If it does, I would glue them.
After which I would check 5 against 6 and 4 against 3 and see how they mate up. If they're gapping and the gaps aren't able to be clamped out then I would joint the edges and try again.
By clamp out, I mean with a fair amount of pressure, not a ton of pressure.
