Messages
Re: Minwax Wipe On Poly Update
David Yoho
Looks good from here :)
You mentioned semi-gloss. I probably use that sheen the most. In fact, I had to buy a can of gloss for the kitchen door job I recently did for a neighbor. However, in comparing the glossiness between the old door and the new one I was working on, I realized it was too glossy. So I applied the final coat using semi-gloss and it matched much better. I installed the door two days ago and the color and sheen were spot on with the others!
