Messages
Re: Elem School Woodwork Bench Design?
Don Stephan
It was a pair of plywood strips held at angle to each other, each with a pair of dowels into the bench top. Third triangular loose piece with a hook at the end. Push the work against the hook, slide the pair between the two doweled pieces to wedge all tight so the work could be planed, card scraped, etc without moving around. Much harder to explain than it was to use.
