Messages
Re: More explanation....
More explanation.... ()
Brian Holcombe
Flooring is produced by a molder, it’s a four sided machine but it does not necessarily produce material ready to be glued face to face. Flat material is best produced by hand feeding a jointer. If you decide to do this you may want to face joint then thickness plane to remove the grooves.
I would personally only glue one or two joints at a time.
Messages In This Thread
Help with a butcher block top
Massive
Re: Help with a butcher block top
More on clamping
weight issue
Re: weight issue
test it
Agree...
Re: Agree... *PIC*
fatal and near fatal errors
Re: Alternating Clamps
Some sage advice
Re: Some sage advice
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
suggestion
Re: suggestion
Re: He is running lengthwise
Yeah, but.....
Wandering OT
Re: Yeah, but.....
Tool to smooth the top??
Knots - character or trouble?
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: Knots - character or trouble?
All planes need the same skills
A couple of questions....
Re: A couple of questions....
glue appplication information
Re: glue appplication information
$12/bdft for 8/4 hard maple? Wow! *NM*
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
