Messages
More explanation....
Re: Some sage advice ()
I am not familiar with maple flooring, locally oak is common and maple is rare. The flooring I have worked with is not perfectly flat on either side. They are anticipating the bottom side to be on the subfloor and out of site and the top side to be sanded heavily. I'm concerned this material will not mate up and make excellent glue joints. Inspect it carefully and and clamp a few pieces together to see if it will "lay up". I suspect you may want to run it through a planer or sander to flatten and clean up both sides, especially the bottom. This will also be good if the flooring is old, dinged, dirty, or oxidized. If you glue up dirty or oxidized wood you get tiny stripes at the joints, especially at the joints.
The second reason I have been concerned about the overhang breaking is the grooves. They reduce the surface area in the joint and thus the strength.
If the grooves are narrow and only educe the glue surface by a small percentage and the joints are clean and tight, I doubt there is any serious danger of a failure, but You have indicated this is all new to you and you have limited equipment and clamps so you might not get the best results. If any of the joints near the "hinge point" fails the over hang could fall off. This could be a "Fatal error" in both senses, the joint failed and it could crush a toe or child. The future is a long time and this joint has to last.
OTOH, I perfectly understand the urge to take "nothing" and make something out of it. It seems I am always trying to take some wood I got cheap or free or have had forever and trying to make something out of it with tools I don't have.
Messages In This Thread
Help with a butcher block top
Massive
Re: Help with a butcher block top
More on clamping
weight issue
Re: weight issue
test it
Agree...
Re: Agree... *PIC*
fatal and near fatal errors
Re: Alternating Clamps
Some sage advice
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
suggestion
Re: suggestion
Re: More explanation....
Re: He is running lengthwise
Yeah, but.....
Wandering OT
Re: Yeah, but.....
Tool to smooth the top??
Knots - character or trouble?
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: Knots - character or trouble?
All planes need the same skills
A couple of questions....
Re: A couple of questions....
glue appplication information
Re: glue appplication information
$12/bdft for 8/4 hard maple? Wow! *NM*
I answered this question in my first reply
Re: I answered this question in my first reply
Are you just adding one board for each glue-up?
Walk before you run
Re: Walk before you run
