Messages
Re: Help with a butcher block top
Yonak
I believe the overhangs will be a problem, especially on the side in the orientation across the boards. I would plan for supports every 18".
Like Don, I wonder how you intend to surface this behemoth. You're going to need plenty of help as it will be heavy.
If you don't go with Bill's advice to glue the boards a few at a time, you may consider slow-set glue.
If clamping is an issue, you could drill holes through each piece and run threaded rods through the holes. These could stay in place to maintain good support and to prevent separation, attaching end pieces to cover the rod ends.
You could bolt the island to the floor to prevent tipping which, I agree with George, would be an issue.
Good luck with this and show pictures.
Messages In This Thread
Massive
More on clamping
weight issue
Re: weight issue
test it
Agree...
Re: Agree... *PIC*
fatal and near fatal errors
Re: Alternating Clamps
Some sage advice
Re: Some sage advice
Save yourself a lot of trouble *PIC*
Re: Save yourself a lot of trouble
suggestion
Re: suggestion
More explanation....
Re: More explanation....
Re: He is running lengthwise
Yeah, but.....
Wandering OT
Re: Yeah, but.....
Tool to smooth the top??
Knots - character or trouble?
Might cause issues? You ever use a hand plane?
Re: Might cause issues? You ever use a hand plane?
Re: Knots - character or trouble?
All planes need the same skills
A couple of questions....
Re: A couple of questions....
glue appplication information
Re: glue appplication information
$12/bdft for 8/4 hard maple? Wow! *NM*
I answered this question in my first reply
Re: I answered this question in my first reply
