Messages
Re: FWW article??
FWW article?? ()
William Duffield
As Mark points out, due to copyright protections, I can't tell you I have the images you want and will send them to you. If I did, do you have an application that will display screen capture images in .tiff format, or would someone need to convert them for you.
Perhaps a more important question: Why do you desire that particular bowsaw design? I would recommend you start with Paul Womack's design, instead. Ask Google to find "bugbear bowsaw" for you. Bugbear started with an antique bowsaw, originally laid out in imperial units, and reverse engineered it to metric. I have a set of plans that I converted back to imperial units, which drastically simplifies the measurements.
