Messages
carbide on 14" saw
What Bandsaw blade? ()
1. I was at a SAPFM meeting where this topic was discussed. A participant was successfully running carbide on a 14" saw. The bottom line, ask Lenox if it will work.
2. A friend runs carbide on a large saw. It yields cuts that are so smooth they can be glued as veneer without further treatment.
3. I doubt tensioning is the issue to be concerned with. Rather it is bade fatigue running over the smaller wheels. Lenox will know if fatigue will be unacceptable.
Messages In This Thread
What Bandsaw blade?
Re: What Bandsaw blade?
Tuning the Saw
Re: Tuning the Saw
Re: Tuning the Saw, I haved tuned....
carbide on 14" saw
So, I talked to Lennox....
A lot of this report puzzles me
Re: A lot of this report puzzles me
Good to know...
Only sharpen the back of the tooth.
how do you hold the blade? *NM*
Re: how do you hold the blade?
(Message Deleted by Poster)
Re: I only sharpen the front of the tooth.
only sharpen the ??? of the tooth. *PIC*
thank you for comprehensive description
Re: thank you for comprehensive description
Re: Bandsaw blades revisited
There's the rub....
Why is all that adjusting necesssary
Re: Why is all that adjusting necesssary
sharpening savings
Re: Why is all that adjusting necessary...Doh!
diamond disk is NOT needed
Re: diamond disk is NOT needed
