Messages
Re: What Bandsaw blade?
What Bandsaw blade? ()
I have a 14" delta and a larger saw. The 14" may not be able to tension a carbide resawing blade effectively without damaging some parts. The tensioning bracket on mine warped and I had to replace it with a stronger one from Iturra Design. The tensioning spring may also need replacing.
I use a 1/2" 3 tpi for almost everything on my 18" bandsaw including resawing. However, I don't try to get smooth resawn surfaces - I run pieces through a performax drum sander if I need them smooth. (most of what I do is cut blanks for woodturning, many of them to the capacity of the saw).
Messages In This Thread
What Bandsaw blade?
Tuning the Saw
Re: Tuning the Saw
Re: Tuning the Saw, I haved tuned....
carbide on 14" saw
So, I talked to Lennox....
A lot of this report puzzles me
Re: A lot of this report puzzles me
Good to know...
Only sharpen the back of the tooth.
how do you hold the blade? *NM*
Re: how do you hold the blade?
(Message Deleted by Poster)
Re: I only sharpen the front of the tooth.
only sharpen the ??? of the tooth. *PIC*
thank you for comprehensive description
Re: thank you for comprehensive description
Re: Bandsaw blades revisited
There's the rub....
Why is all that adjusting necesssary
Re: Why is all that adjusting necesssary
sharpening savings
Re: Why is all that adjusting necessary...Doh!
diamond disk is NOT needed
Re: diamond disk is NOT needed
