Messages
Re: What Bandsaw blade?
What Bandsaw blade? ()
Hi Barry
Choosing a blade width and compoition depends on how much tension your bandsaw can sustain. Carbide blades are the stiffest, and I suspect that none will be tensioned sufficiently by your bandsaw to work satisfactorally. Without enough tension, their performance suffers noticeably. The only carbide blade I would suggest may work on your bandsaw is the Resaw King, as it is the thinnest and requires the least tension. I am not sure how wide they are, but you could not go wider than 1/2".
Next in the chain are bi-metal blades, and you may get away with one that is no wider than 1/2" (in reality, a 1/2" blade is capable of a wide range of cuts).
I would stay away from the Woodslicer blades. They do cut well, but the steel seems very soft, and they do not hold an edge for long - especially in my West Australian timbers.
For reference, I use a 1" Lenox Woodmaster CT for resawing and 1/2" bimetal blades from a local supplier for all else. I resharpen these myself, and get about 4-5 sharpenings per blade. My bandsaw is a 17 1/2" Hammer N4400.
Messages In This Thread
What Bandsaw blade?
Tuning the Saw
Re: Tuning the Saw
Re: Tuning the Saw, I haved tuned....
carbide on 14" saw
So, I talked to Lennox....
A lot of this report puzzles me
Re: A lot of this report puzzles me
Good to know...
Only sharpen the back of the tooth.
how do you hold the blade? *NM*
Re: how do you hold the blade?
(Message Deleted by Poster)
Re: I only sharpen the front of the tooth.
only sharpen the ??? of the tooth. *PIC*
thank you for comprehensive description
Re: thank you for comprehensive description
Re: Bandsaw blades revisited
There's the rub....
Why is all that adjusting necesssary
Re: Why is all that adjusting necesssary
sharpening savings
Re: Why is all that adjusting necessary...Doh!
diamond disk is NOT needed
Re: diamond disk is NOT needed
