Messages
Re: What Bandsaw blade?
What Bandsaw blade? ()
David Yoho
I don't think you'll gain anything on that saw using a carbide tipped blade for resawing that one of the better non-carbide blades will do for you.
I'm fortunate to have two bandsaws. The 14" Delta without riser does all the normal and curved cuts I need using regular blades. My Mini Max 16 is set up with a 1-inch Lenox Tri-Master carbide blade for resawing and cutting large stuff. The MM-16 can tension the wide blade easily and has more than enough power to cut through stuff the Delta would struggle with. Save yourself the extra money and just use a good blade on your Delta.
Messages In This Thread
What Bandsaw blade?
Tuning the Saw
Re: Tuning the Saw
Re: Tuning the Saw, I haved tuned....
carbide on 14" saw
So, I talked to Lennox....
A lot of this report puzzles me
Re: A lot of this report puzzles me
Good to know...
Only sharpen the back of the tooth.
how do you hold the blade? *NM*
Re: how do you hold the blade?
(Message Deleted by Poster)
Re: I only sharpen the front of the tooth.
only sharpen the ??? of the tooth. *PIC*
thank you for comprehensive description
Re: thank you for comprehensive description
Re: Bandsaw blades revisited
There's the rub....
Why is all that adjusting necesssary
Re: Why is all that adjusting necesssary
sharpening savings
Re: Why is all that adjusting necessary...Doh!
diamond disk is NOT needed
Re: diamond disk is NOT needed
