Messages
Re: If FWD, check CV joint -typical symptom
Matt
Do you feel/hear the thumping only when applying brake pressure or does it show up when simply moving/turning? When parked and you apply the brakes, do you hear it as well?
Make/model of car? Issues with CV joints usually progrees from a slight noise and get worse over time, which seems different than what you are describing.
