Messages
Re: OT- vehicle brake question??
Mark Nowicki
Did you tighten and torque everything?
To change the rotors you had to take off the caliper brackets. On my Dodge the torque for those is over 90 pounds.
The pads fit OK? Did you replace the stainless clips on the caliper brackets?
I would redo the left front. Sounds like something is flopping around.
If everything checks out , switch the tires and see if the noise moves to the other side.
