Messages
slotted screws
>>>. I need to make or find a very accurately ground screw driver. It wanted to cam out. I have it soaking with penetrating oil.
I bought a set of gunsmith screwdrivers which are precision flat ground. Grip very well. I have flat ground my own a custom size for a good fit as needed.
Also, back when I worked on motorcycle engines a lot a hand-held manual impact driver was my best friend. A lot of screws were Philips then which were notorious for stripping the heads. I would cut a slot across the top of the screw and use the impact driver with a flat bit, smacking with a hammer. The combination of shock from the impact, strong downward rotational force, and penetrating oil never failed to remove an otherwise impossible screw.
Mine looks a lot like this. https://www.amazon.com/Lisle-29200-Hand-Impact-Tool/dp/B0002NYDRG These things last forever.
I always replace problem screws with socket (allen) screws.
